A management module component, processing received events from the I/O blades, has detected an invalid socket file descriptor. This is possibly due to a software programming error. The device manager component at MM will restart IO slot if configured to do so.
No remedy is available.
Error
A conduit receive event detected a bad file descriptor of %eventSck% for slot %slotNo% and Tcp port %tcpPort% - EventID:%entId%.
| Name | Type |
| slotNo | uInt |
| tcpPort | uInt |
| eventSck | sInt |
| entId | String |
